587,089 active members*
2,911 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Fanuc lathe post
Results 1 to 7 of 7
    Jan 2007
    14
    Fanuc lathe post
    Hello.
    I need a post for a lathe Fanuc 16iTB or Fanuc 0iTC
    I try with fanuc post but i have a problem with C axis.
    Please help me .
    bye
    Jun 2003
    73
    You can try this one, it should get you close. I will watch this thread if you have any questions or tweaks.
    Attached Files Attached Files
    Mike W.
    Jan 2007
    14
    Don't work
    hello
    This work
    O0001
    N10 (CONTORNATURA)
    N15 (EC140B25-3C14)
    N20 T0101
    N25 M10
    N30 G28 C0.
    N35 G97 S2273 M74
    N40 G17
    N45 G00 X51. C0.
    N50 Z50.
    N55 Z2.
    N60 G98 G01 Z-23.2 F409
    N65 G112
    N70 G41 X36.151 C7.425
    N75 G03 X30. C0. R10.5
    N80 X70. R10.
    N85 X30. R10.
    N90 X36.151 C-7.425 R10.5
    N95 G40 G01 X51. C0.
    N100 G113
    N105 Z-21.2
    N110 G00 Z50.
    N115 X300. Z300.
    N120 M75
    N125 M11
    N130 M30
    Mar 2006
    1013
    What did the code look like from the Edgecam output?
    What needs to be changed?
    Does it run the machine, or you just dont like the way it looks?
    Mike
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Jan 2007
    14
    Post 16iTB
    Hello.
    Can yous ee this example.
    By
    Jun 2003
    73
    I did a little bit of tweaking to the post that I sent the other day and it's there except for a couple of M codes. They can easily be added wherever they are needed. Once again, Code Wizard can you get you 95% there right out of the box, the things that do need tweaking are usually in the toolchange areas and program start.
    I am sending the edited post and ppf
    Mike W.
    May 2007
    51
    Ahh, it sure looks like the programs I make on my SL150SMC.
    I'm "stealing" this post, and hope to be able to convert it.
    Thanks.
  1. Fanuc Oi-Tb control post for lathe for Gibbs
    By metalman21 in forum GibbsCAM
    Last Post: 12-10-2010, 07:31 PM
