588,281 active members*
5,186 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Main spindle and live tooling turning at the same time?
Results 1 to 7 of 7
    Jun 2013
    3
    Can this be done while not in c axis milling mode?
    Thanks for any responses
    Mar 2003
    2932
    I know that it can on a Doosan. What kind of machine do YOU have?
    Dec 2009
    977
    spindle and tool rotate the same time???never possible ,should be interlocked on the ladder
    say to me one operation you want to do when u turn spindle and come with a mill tool or a drill tool on the piece.
    what operation u can do while spindle rotate???????
    i think only if you want to grind something with a small stone !!!!!?????
    turn the grinding tool with the tool roatting and spin spindle the oposite direction
    Feb 2009
    6028
    Usually an option. We have it on our Mazak, and I know mori also sells it as an option. Not too many uses for it, but it's nice for composites.
    Jun 2007
    87
    It's limited because its for very special operations like making flats on the outside diameter like hex etc.. and if you're making tons of them like on pipe fittings industry. You wouldn't believe how fast those flats can be done using simutaneous mill turning compared to conventional c axis miling.
    Mar 2003
    2932
    Quote Originally Posted by zavateandu View Post
    what operation u can do while spindle rotate??????? <------------------------------------- See below.
    One example:
    I want to run a small drill into the end of the part (on center) at 6000 RPM.
    The main spindle max RPM is 2,500, live tool spindle max RPM is 4,000. If I run the main spindle at 2,000 and the live tool at 4,000 RPM, voila! I can run the drill at the correct RPM.
    Just because you've never done it doesn't mean it's "never possible".
    Feb 2009
    6028
    Or you need to turn a lathe in to a rotating router for composites.
  1. Simultaneous Main and Live tooling
    By jimmyjolly in forum Okuma
    Last Post: 02-01-2012, 11:39 PM
  2. Lathe live tooling as spindle?
    By sergizmo in forum Benchtop Machines
    Last Post: 08-28-2008, 11:03 PM
  3. Replies: 8
    Last Post: 07-07-2007, 04:49 AM
  4. Need help with live tooling on a FANUC 10Te/f
    By kangarabbit in forum Fanuc
    Last Post: 03-30-2006, 10:05 AM
  5. RFQ small turning w/ live tooling
    By Shizzlemah in forum Employment Opportunity
    Last Post: 04-22-2005, 01:20 AM
