603,844 active members*
3,407 visitors online*
Results 1 to 18 of 18
    Jun 2008
    13
    Fanuc O-M lost parameters
    Battery Backup went dead on machine while sitting. Had all kinds of errors of course when I replaced battery. Got parameters put back in but still have one error code 414 x axis. Does anyone know what line controls this or do I have to look through all the parameter #'s again?
    Oct 2008
    106
    Alarm 414, need to check DGN720 to 727 to see which bit is on
    You should doubdle check your parameter start from #8100
    Ahn Vuong
    Jun 2008
    13
    Thanks for your help! I checked the DGN 720 to 727 on 720 I had a 00100000 but after check my 8100 on I found some wrong changed them and reset it no more code! Now I can't zero return the machine because when I turn the dial it goes from edit - auto - mdi - handle - teach in handle - teach in jog - jog - zero return when I slide the handle on the screen from right to left it says edit, auto, mdi, hndl, hndl, hndl, tjog, jog but it won't show zrn. What is going on? Thanks
    Oct 2008
    106
    You should double check all the Option parameter start from 900
    Also need to remember to put all machine timer and keep relay back??
    Ahn Vuong
    Jun 2008
    13
    What do you mean by machine timer and relay? Thank you
    Oct 2008
    106
    I am sorry do not know how to explain Timer & Keep relay
    When Battery Backup went dead, machine not just lost all parameter, also all your program, timer and keep relay gone too, you may need to contact machine builder to get a copy of the timer and keep relay for your machine
    Who is the manufacturer??
    Ahn Vuong
    Jun 2008
    13
    Thank you for all your help! Company is YCI supermax rebel 1 machine. I called them for parameter put them all in. I checked the parameters in 900 and when I checked 0901 it was wrong. I tried to enter number but it said "Warning preset #901 #2 this parameter destroy next file in memory from file 1 to 15 now neccessary to clean these files which do you want? del clear these files or cancel? What does this mean? Also I will call them tomorrow to get information.
    Thank you
    Oct 2008
    106
    You want to choose the DEL, it is going to delete the program only but you don't have any program anyway
    Ahn Vuong
    Oct 2008
    106
    Also request them a Macro program for your machine ATC
    Ahn Vuong
    Jun 2008
    13
    Thanks fir all your help! I got the keep and relay settings and put them in. Almost there now it has zer return back but twwo mdi settings instead of one. Now it shake very bad when I home in y axis and gives me error 414 when I try to home in y. They had me reset holding p and cancel while turning on.but didn't help. Thank you in advance!
    Oct 2008
    106
    Holding P and Cancel Key while power up control only when the servo can't find it home position then you do that
    "Y Axis shake very bad when you do Zero return and also error 414"
    You shoud double check parameter start from #8200
    Do you have the origenal parameter from this machine??
    Ahn Vuong
    Jun 2008
    13
    They sent me original parameters and also procedure to reset home but it didn't work. Do you have to hold down cancel and p together and where is P? I will check 8400 peremeters
    Thankyouu
    Oct 2008
    106
    What do you mean by it didn't work?? are you talking about Zero return doesn't work or servo alarm 414 come up when you try to move the Y Axis?
    The "P and Q" key they are locate on the Keypad, normaly is right side of the CRT, you have to press and hold down P, Q and CAN key while power up machine, and wait untill control go to ready position before release P,Q, CAN
    Ahn Vuong
    Jun 2008
    13
    I had some numbers wrong in the parameter section, it will zero return now. The only thing now is the mode switch when it goes from mdi to handle it says mdi on screen on both settings is that normal? Thank you for everything again!
    Oct 2008
    106
    I think you still missing a parameter some where, I am sorry I do not know which one to change to fix the problem, you should double check again all the parameter and specialy the #900 to 930
    Ahn Vuong
    Jun 2008
    13
    Put program in to test and spindle goes ccw I must have parameter set wrong. Also try to send or receive program but get bad characters on pc screen. Are there parameters for rs232 setting?
  17. #17
    Mar 2009
    5
    there are settings to turn on RS232 inputs. turn the handle to MDI i believe, look in settings screen, page down for "input mode" change 0 to 1 or vise versa..
  18. #18
    Oct 2008
    106
    Need to check your baud rate, Parameter 0552 and 0553
    If your PC set 4800 then change parameter 0552 & 0553 to 10
    If 9600 then parameter set at 11
    Ahn Vuong
  1. Lost fanuc 3T parameters
    By erikturn in forum Fanuc
    Last Post: 09-24-2014, 09:00 AM
  2. fanuc series OM parameters lost
    By m_ghaff2000 in forum Fanuc
    Last Post: 01-24-2014, 08:42 PM
  3. Lost parameters for Takisawa fanuc 3t
    By rrbird76 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2009, 10:05 PM
  4. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  5. Replies: 2
    Last Post: 02-08-2008, 09:00 AM
