587,684 active members*
3,111 visitors online*
Results 1 to 7 of 7
    Feb 2006
    213
    Fanuc O-MC spindle problem
    I have a vertical machining center having Fanuc O-MC cnc system. It's spindle motor being stopped in automatic mode while it's feed is not getting hold.
    It's spindle drive # A20B-1003-0020 displays shows Alarm No.= 11
    I donot have it's manual not even it's alarm discription. ( Alarm 11 ?)
    Spindle motor encoder is directly mounted on spindle drive shaft. spindle motor to spindle 1:2 ratio. ( Belt driven ) & orientation card is mounted on spindle drive. Could you also tell me the parameter no. for orientation position (Angle).
    kindly help me & send me it's detailed manual.
    inthezone Guest
    I believe alarm 11 is "No feedrate commanded". You can probably email the company to get the manuals you need.
    Feb 2006
    213
    Quote Originally Posted by inthezone View Post
    Alarm No. 11 is being appeared on the spindle drive seven segment display, spindle gets stop & feed is moving.
    Feb 2006
    213
    Somebody help me as Alarm No. 11 is being appeared on the spindle drive seven segment display, spindle gets stop but feed is moving.
    ALARM No. 11?
    Nov 2003
    98
    Alarms on a AC Spindle Servo Unit, Serial Interface S Series
    These were copied from another source. I cannot verify they are all correct.
    “A” Program Rom abnormality (Not Installed)
    AL-01 Motor Overheat
    AL-02 Excessive speed deviation
    AL-03 DC Link fuse blown
    AL-04 Input fuse blown
    AL-05 Control power supply
    AL-07 Excessive Speed
    AL-08 High Input Voltage
    AL-09 Excessive load on main circuit section
    AL-10 Low input voltage
    AL-11 Overvoltage in DC link section
    AL-12 Overcurrent in DC link section Transistor faulty, Or base drive waveform voltage missing on the top card
    AL-13 CPU Internal data memory abnormality
    AL-15 Spindle switch/output switch alarm
    AL-16 RAM Abnormality
    AL-18 Program ROM checksum error
    AL-19 Excessive U phase current detection circuit offset
    AL-20 Excessive V phase current detection circuit offset
    AL-24 Serial transfer data error
    AL-25 Serial transfer data stopped
    AL-26 Disconnection of speed detection signal for C’s contouring control
    AL-27 Position coder signal disconnection
    AL-28 Disconnection of position detection signals for C’s contouring control
    AL-29 Short-time overload
    AL-30 Input circuit overcurrent
    AL-31 Speed detection signal disconnection motor restraint alarm
    AL-32 Abnormality in RAM internal to LSI for serial data transfer
    AL-33 Insufficient DC link section charging
    AL-34 Parameter data setting beyond allowable range of values
    AL-35 Excessive gear ratio data setting
    AL-36 Error counter overflow
    AL-37 Speed detector parameter setting error
    AL-39 Alarm for indicating failure in detecting 1-rotation signal for C’s contouring control
    AL-40 Alarm for indicating 1-rortation signal for C’s contouring control not detected
    AL-41 Alarm for indicating failure in detecting position coder 1-ratation signal
    AL-42 Alarm for indication position coder 1-rotation not detected
    AL-43 Alarm for indicating disconnection of position coder signal for differential speed mode
    AL-46 Alarm for indicating failure in detecting position coder 1 rotation signal in thread cutting operation
    AL-47 Position coder signal abnormality
    AL-48 Position coder 1-rotation signal abnormality
    AL-49 The converted differential speed is to high
    AL-50 Excessive speed command calculation value in spidle synchronization control
    AL-51 Undervoltage at DC link section
    AL-52 ITP signal abnormality 1
    AL-53 ITP signal abnormality 2
    AL-54 Overload current alarm
    AL-55 Power line abnormality in spindle switching/output swicthing
    Nov 2003
    98
    Diagnostics
    #452 Turret adjust switch. Make all 1's then cycle estop to clear tool clamp alarm and allow you to tool change to another tool.
    #016 X axis home limit (Bit 5)
    #017 Y axis home limit (Bit 5)
    #018 Z axis home limit (Bit 5)
    #720 X axis alarm bits
    #721 Y axis alarm bits
    #722 Z axis alarm bits
    Parameters
    #700 X axis soft limit +
    #701 Y axis soft limit +
    #702 Z axis soft limit +
    #703 4th axis soft limit +
    #704 X axis soft limit -
    #705 Y axis soft limit -
    #706 Z axis soft limit -
    #707 4th axis soft limit -
    I believe these are right. May have the +/- backwards.
    #535 X axis backlash adjustment
    #536 Y axis backlash adjustment
    #537 Z axis backlash adjustment
    #128 Tool # (actual tool in spindle)
    #129 Tool # (number of tools magazine will hold)
    #9122 Tool Change spindle orientation adjustment. Minus=CCW Plus=CW
    #22 Home Position Memory X=bit 0, Y=bit 1, Z=bit 2
    Bob
    Feb 2006
    213
    Quote Originally Posted by bob1371 View Post
    Diagnostics
    Parameters
    Bob
    Thank you so much for your prompt reply & sending me detailed alarm list.
    Best regards
  1. Fanuc/Hurco Spindle Drive Problem
    By gregm1976 in forum Fanuc
    Last Post: 12-18-2013, 08:52 AM
  2. Fanuc 0M Spindle Speed Problem
    By inthezone in forum Fanuc
    Last Post: 08-01-2007, 10:14 PM
  3. Replies: 6
    Last Post: 05-28-2007, 03:50 AM
  4. Fanuc 0i-MC controller Spindle Problem
    By PJ Engineering in forum Fanuc
    Last Post: 05-18-2007, 04:01 PM
  5. spindle problem with tnc 151
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2007, 03:45 PM
