I am trying to change parameter 3202 ne9 on my machine and it is giving me a write protect message. want to read and writ 9000 programs. i have parameter write enabled and the machine edit key is on and in MDI mode. does anyone know if there is a parameter that will prevent you from changing anything even if you have the key and parameter write enabled.
Also when i try to type a [ it is giving me a paranthesis instead. need to write brackets not parenthesis. is there a parameter that would help fix this issue.
