586,069 active members*
3,389 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc Oi-TC PCMCIA CF CARD won't load file to controller
Results 1 to 4 of 4
    May 2015
    5
    I have a lathe with a fanuc Oi-TC controller, machine was purchased used and originally communicated with rs232
    i have purchased a pcmcia to cf card adapter, cf card 128mb transend industrial CF220i
    the controller can see the files on the card
    i have been able to delete files on the card from the controller
    i have formatted the card using the controller
    i/o para is set to 4 (memory card)
    process i am trying with no great success is below
    >system>all i/o>card>oprt>Nread>fset(O1997.txt)>Oset (1997)>EXEC
    i get a breif flash of lsk and input but no other msgs and the file isn't in my controller directory, getting stuck and playing around i also tried Fread
    machine is in edit mode, key is in edit position (tried both positions)
    Any suggestions here would be much appreciated
    May 2015
    5
    Re: fanuc Oi-TC PCMCIA CF CARD won't load file to controller
    and just like that after you ask a question the answer finds you,
    i did try quite a number of things but im 90% confident the change i made to make this work was one of the following below
    tv check set to 0
    or i feel more likely
    my solidworks code did not have % symbols at the start and end of the .txt file, all i did was add these at the start and end and the file uploaded to the controller no problems, really hope this can assist someone in the future
    Mar 2021
    14
    Hello,
    Make a new program in the control,
    Then in edit mode make it like this.
    O1234; (call mem card prog)
    M198 P0001;
    M30
    Name your program on the CF card "O0001" and make it have to extension, so its just a "File" on the pc.
    This way you can run huge programs and its the preferred way to run from cf.
    Make sure IO is on 4 in settings.
    May 2015
    5
    Quote Originally Posted by Max-Eley View Post
    Hello,
    M198 P0001;
    M30
    i’ll have to give that a shot, i’m struggling at the moment to find a post processor for an oi-tc, none of the standard post processor seem close in format
  1. Using PCMCIA Ethernet card (FANUC)
    By redray in forum Fanuc
    Last Post: 07-27-2016, 06:19 AM
  2. help! - Fanuc 210i PCMCIA card issues
    By layy in forum Fanuc
    Last Post: 07-29-2015, 05:22 PM
  3. PCMCIA card on Fanuc 18M
    By buildyourown in forum Fanuc
    Last Post: 02-23-2013, 06:56 PM
  4. Fanuc 18i PCMCIA card question
    By TDavid in forum Fadal
    Last Post: 10-27-2012, 02:54 AM
  5. Fanuc 16 i MB PCMCIA Card
    By ess178 in forum Fanuc
    Last Post: 12-24-2011, 06:05 AM
