587,192 active members*
2,261 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Oi-TD Work Shift Offset is Way Off
Results 1 to 5 of 5
    Jun 2006
    17
    Hello,
    We just got in a 2012 Hwacheon HI-Tech 200A lathe with a Fanuc Oi-TD controller. I'm fairly familiar with these machines and the Fanuc controller, as we have a 2008 Hi-Tech with a Oi-TC controller. So i'm scratching my head here trying to figure out why this machine won't set my workshift offset correctly. I go through my typical routine of setting the tool off the pre-setter, face off the part and set my ZERO > INPUT in the Z Measurement box.
    Well once I go to start the program, my tool wants to go an extra 10 inches past my part. I double checked my tool on the pre-setter with the same result. Has anyone experienced anything like this with an Oi controller? I know Fanuc can be a little inconsistent between controllers, maybe am I doing something wrong here?
    I attached some picture of my work shift offset page, along with a second image with the program running and distance to go active.
    Thanks for the help.
    Edit: Our other machine just finished a job so I was able to compare them side by side. Our working machine sets the workshift offset off (only what I can assume) is the toolsetter location, and this new machine always inputs the Machine Z coordinate as the shift value. I hope that makes sense. Maybe they were not using the tool setter and I need to adjust parameters/settings for this to work.
    - Matt
    May 2016
    526
    Re: Fanuc Oi-TD Work Shift Offset is Way Off
    Is the probe set correctly ?
    Jun 2006
    17
    Quote Originally Posted by mbservice View Post
    Attachment 405466Click image for larger version.
    That's what I'm leaning towards too. I've been digging around in the tool setter parameters and I found that the ZM 5018 parameter is empty. Now I'm working on adjusting that parameter and see if something changes.
    - Matt
    Dec 2009
    968
    i think they do not use the setter but use the tool number 1 as set the Z0,cut off the face of piece and set 0 in the shift value and tool number 1 has no geometry in offset on Z value and all other tools are called and measured as Z0 touching the face of the piece.
    Jun 2006
    17
    So I figured out the issue today, it was all in the 5015-5018 parameters that needed to be adjusted in a metric format. It looks like the previous owners just used the Q setter for the OD/ID and set the tool manually off the part. Now everything is working perfectly when I ZERO > INPUT in the measurement work shift.
    I also found out why this machine was giving me the machine zero in the shift value, unlike our other Hwacheon. Our other Hwacheon had coordinates inputed into the G54 offset, so when I set the zero it gave me a shift value relative to those coordinates. Eventually I will have to clear out the G54 and re-dial in the Q setter like I did with this new one. Phew, I'm glad this is over! Thanks again everyone.
    - Matt
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. M-Plus Work offset shift values getting ignored...
    By MACKAY9999 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2016, 02:15 PM
  3. Replies: 1
    Last Post: 05-22-2016, 10:59 PM
  4. Work shift on lathe(fanuc)
    By eldo in forum Fanuc
    Last Post: 08-25-2012, 09:09 PM
  5. Help setting work shift offset in LX3 ?
    By panaceabea in forum Hyundai Kia
    Last Post: 05-29-2011, 03:51 PM
