603,316 active members*
2,805 visitors online*
Hybrid View
    Oct 2009
    9
    Fanuc OM-B G52 Offset Enable
    I have a fairly old CNC router with a Fanuc OM-B controller. When running sub programs using work offset G52, I get an 010 P/s Alarm, invalid G code. I am assuming this is caused by the controller not processing the G52 code.
    My question is, is the G52 turned on by an option parameter (900's) or perhaps a diagnostic or is it simply not supported by this controller.
    Ed
    Mar 2006
    158
    HI Ed -
    I did not see it as an option parameter in my OM-C parameter lists.
    I presume they are approximately the same, but no way for me to tell.
    I would give Fanuc a jingle and see what they say.
    Sep 2008
    138
    Quote Originally Posted by NCEd View Post
    Ed
    PM me your email
  1. Enable shift key for Fanuc 6M.
    By ckirchen in forum Fanuc
    Last Post: 02-04-2012, 11:13 AM
  2. PWE enable in Fanuc OiTB system
    By KHN in forum Controller & Computer Solutions
    Last Post: 01-30-2011, 06:15 PM
  3. Fanuc 18-T G83 cycle enable
    By CoffinJoey in forum Fanuc
    Last Post: 12-27-2010, 08:32 PM
  4. Replies: 2
    Last Post: 05-25-2009, 05:22 PM
  5. Spindle enable alarm Fanuc OTB
    By hien100881 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-21-2007, 08:29 AM
