588,124 active members*
4,637 visitors online*
    Apr 2010
    FANUC OM-D COMMUNICATION ISSUE
    I HAVE AN AMERI-SEIKI V-MILL WITH A FANUC OM-D CONTROL. IT HAS STARTED GENERATING COMM ALARMS WHEN TRYING TO UPLOAD PROGRAMS. ALARMS VARY SUCH AS 85,86, AND 001 DURING UPLOAD TO MACHINE. IT WILL DOWNLOAD A PARTIAL PROGRAM TO COMPUTER THEN GENERATE ALARM 86.THIS WAS AN INTERMITTENT PROBLEM FOR A COUPLE DAYS BUT IS NOW CONSTANT. I USE PREDATOR SOFTWARE WITH A USB TO SERIAL ADAPTER. I HAVE CHECKED CABLE, AND PARAMETERS AT COMPUTER AND MACHINE. ALL MY OTHER MACHINES ARE COMMUNICATING FINE. I HAVE ALSO TRIED SETTING UP AND USING THE SECOND PORT ON THE BOARD IN THE CABINET (M74 I THINK IT IS) BUT PROBLEM IS THE SAME. I AM SUSPICIOUS OF THE BOARD ITSELF BUT I'M NOT SURE. DOES ANYONE HAVE ANY OTHER IDEAS OR SUGGESTIONS? ANY WOULD BE APPRECIATED. THANKS!
    May 2009
    181
    might be a bad memory board.. recheck all the parameters for rs232..
  1. Communication issue with a EZ Track DX with Computer
    By biker_eh in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2008, 01:43 PM
  2. fanuc 21I-T communication
    By bob@apc in forum Fanuc
    Last Post: 05-02-2008, 10:37 PM
  3. Fanuc Om Communication Problem
    By aghobby in forum Fanuc
    Last Post: 02-27-2007, 07:01 PM
  4. Fanuc 3T Communication
    By dpirog in forum Fanuc
    Last Post: 08-24-2005, 09:24 PM
  5. Ethernet Communication with Fanuc 18i-T
    By smabhyan in forum Uncategorised CAM Discussion
    Last Post: 10-22-2003, 04:45 PM
