603,942 active members*
4,019 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc OM-D spindle orientation parameter?
    Jul 2007
    41
    Spindle is locked in the wrong position at tool change. is there a parameter for indexing spindle to correct position?
    Oct 2008
    106
    try parameter 6577, increase or decrease the value it should work.
    if machine run into wrong position again, you should check the timing belt or the spindle belt
    Ahn Vuong
    Feb 2007
    317
    if it doesn't work, try prm#6531 (Position coder method orientation stop position)
    #6577 is Orientation stop position shift amount
    I think both work
  1. FANUC-6M SPINDLE ORIENTATION
    By CHANDRU in forum Fanuc
    Last Post: 04-18-2009, 07:05 PM
  2. Replies: 0
    Last Post: 10-28-2008, 03:39 AM
  3. Manual for Fanuc Spindle Orientation board
    By MetLHead in forum Fanuc
    Last Post: 02-14-2008, 09:23 PM
  4. Spindle orientation
    By StampCraft in forum Haas Mills
    Last Post: 11-11-2007, 12:31 AM
  5. Replies: 1
    Last Post: 10-30-2005, 09:38 PM
