603,979 active members*
1,457 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM. Parameters lost. X axis wrong direction.
    Nov 2011
    I'm helping someone get a machine running.
    It has a Fanuc OM controller on it.
    The battery went dead and all the parameters were lost.
    They have just about zero documentation.
    Someone with the same machine gave him their parameter list values. They input it.
    Simple tests on the machine show the X axis is going the wrong way.
    Where do I start getting this machine going again ?
    Where do I get a list of the Fanuc parameter meanings ?
    Thanks !
    Dec 2003
    24260
    Send me a email add by P.M.
    Al.
    Albert E.
    Dec 2003
    24260
    Email sent, the servo dir. is usually a parameter that is changed from 1 to -1 for direction.
    Al.
    Albert E.
  1. Z axis backlash that drives the wrong direction
    By Kingjamez in forum Benchtop Machines
    Last Post: 10-05-2010, 03:46 AM
  2. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  3. EZ Trak axis running wrong direction
    By spindlenut in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2010, 05:38 AM
  4. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  5. integrex 200 II SY b axis wrong direction
    By smile in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2006, 05:09 AM
