603,958 active members*
2,353 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OMC not display program in dripfeed mode
Results 1 to 9 of 9
    May 2008
    110
    Hi all
    My CNC machine used Fanuc OMC, every thing seem OK, but I can't see the program on screen when I use dripfeed mode( the machine can work untill the end of program, but I can't check witch the command 's doing). Please guide me how to fix this problem. Thanks you so much.
    Nam
    Mar 2003
    2932
    From the 0M-C Operator's Manual:
    In DNC operation mode, no program can be displayed. Only the
    current block and subsequent block can be displayed.
    Dec 2009
    1122
    you will never see the program on 0M
    the only way is just check the "distance to go" and know where the machine is moving
    May 2008
    110
    @dcoupar and @ zavateandu: Thanks you so much.
    Mar 2005
    817
    Is there a parameter for this?
    Apr 2009
    1401
    In order for a control to display the drip-fed program, it would have to read it in first; that requires sufficient remaining memory. If that memory is available, you may as well load the program and run it from memory. That way is IS displayed.
    Feb 2014
    Dahlih MCV 1350 (FANUC OM series) parameter files that I need Can you help friends who are over the counter
    Dec 2009
    1122
    are froma 6M sorry
    i can not delete pictures
    Apr 2016
    5
    Re: Fanuc OMC not display program in dripfeed mode
    how can you display the current block ?
    i want to run in dnc mode a program from memory and i want to see the current line?
  1. Replies: 5
    Last Post: 05-29-2013, 07:04 PM
  2. Replies: 8
    Last Post: 11-30-2012, 10:15 PM
  3. Replies: 0
    Last Post: 09-10-2012, 04:57 AM
  4. Replies: 3
    Last Post: 07-13-2011, 02:32 PM
  5. Need Help to Set cnc Dahlih MCV 1350 in Dripfeed mode
    By aslam819 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2011, 01:58 AM
