603,783 active members*
2,686 visitors online*
    Apr 2012
    Fanuc OP-B Alarms!
    Hello, I am currently having a problem with a Fanuc OP-B controller hooked up to a Centrum 2000 2axis table used with a rofin-sinar laser cutter. The problem that i am having is overtravel errors in all directions of the axis, X+ and X- Y+ and Y-, as well as the overtravel in and out, overtravel left and right. Does anyone have information on why i am getting all these errors at once? Personally, I am under the impression that it is an I/O board error and needs to be replaced.
    Any thoughts? We just bought this machine and I really dont know much about it. After a week of working great one of my employees decided to change out the fitting on the foot pedal that opens and closes the workholders, and did not turn off the power to the machine, and may have arced the 6+v that is running through one of the wires across the table of the machine. There are no fuses on the boards and no circuit breakers are blown.
    Apr 2009
    1401
    You have most likely a blown fuse or tripped overload. It is also possible that a wire is disconnected due to the arcing. Even a blown board is possible. Look at the electrical diagram and trace the +24V circuits.
  1. Fanuc 0t-C 409, 414, 424 alarms
    By acerocket in forum Fanuc
    Last Post: 12-08-2015, 06:56 AM
  2. Fanuc 21-tb alarms
    By Hlynur in forum Fanuc
    Last Post: 12-06-2012, 04:44 AM
  3. Fanuc O-T Alarms
    By deltaguy in forum Fanuc
    Last Post: 06-17-2012, 01:45 AM
  4. 12 alarms on Fanuc 18i-TB
    By bobancurug in forum Fanuc
    Last Post: 04-17-2011, 08:49 PM
  5. Fanuc 400 alarms and other
    By alphatad in forum Fanuc
    Last Post: 02-04-2008, 03:32 PM
