603,793 active members*
3,209 visitors online*
Results 1 to 7 of 7
    Oct 2008
    3
    Fanuc OT-C Ladder
    Hi ever one
    How can I take backup of Fanuc OT-c Ladder? did Fanuc Ldder III work with OT-C.
    Jan 2009
    117
    You can use any commercial EEPROM programmer / reader and back the ladder up as HEX or BIN file. Not possible to view or edit the LADDER.
    If you want to see/edit the ladder you need a DOS or WIN98 PC with the original FLADDER software as well as a FANUC PC PROGRAMMER unit.
    With FS-0TC you can also try FLADDER but you need to plug in the FANUC LADDER EDITING card on the master PCB and then download through the RS-232 port.
    Don't even ask to view / edit FS-3, FS-5, FS-6, FS-10/11/12 on PC. Exclusive use of FANUC P-G or older dedicated equipment and the appropriate software and programming hardware.
    Nov 2006
    175
    Quote Originally Posted by hrh View Post
    You can use any commercial EEPROM programmer / reader and back the ladder up as HEX or BIN file. possible to view or edit the LADDER.
    Red is mine comment. For FS-0 model A..D DOS Fladder is necessary. Bin/hex can be converted to Fanuc format
    FS3, 6 - possible to edit on PC with appropriate software
    FS5 also, but big pain, there are usually big parts in 6800 assembly.
    Jan 2009
    117
    f-bu
    Where can I get software to convert hex/bin files to FLADDER format?
    I am really interested to know which software is used for FS-3, 6 and the cost.
    Please let me know.
    Nov 2008
    37
    Hello, may this link could be useful for another Fladder FAQ http://cncfanuc.blogspot.com
    i wrote two software for fapt ladder compile and discompile
    1.#ex--->oe1,oe2 for write eprom (two chips eprom)
    2.oe1,oe2---->#ex for discompile .it can display eprom ladder on pc
    i only used this version for fanuc 0L/OM/0P/0TC
    May 2011
    pmc-l is for 0tc, and you need a eprom writer or pgmate, to make ladder, only whit fapt ladder 1, if you dont have a eprom writer, i can make a #ex whit oe1 and oe2 obj files.
  1. fanuc-o ladder
    By Bill Clark in forum DNC Problems and Solutions
    Last Post: 09-29-2011, 07:35 PM
  2. EDITING WITH FANUC LADDER III
    By CHAD LAWSON in forum Fanuc
    Last Post: 01-30-2009, 01:36 PM
  3. FANUC LADDER
    Last Post: 12-08-2008, 07:47 PM
  4. How to use Fanuc Ladder III on OM
    By Namnp2007 in forum Fanuc
    Last Post: 08-06-2008, 05:08 AM
  5. Fanuc ladder
    By guhl in forum Fanuc
    Last Post: 12-07-2007, 07:54 PM
