587,307 active members*
3,683 visitors online*
    May 2022
    4
    Fanuc OT Cycle Counter
    Hi All,
    I have a new to me Yang ML25A CNC Lathe with a Fanuc OT Control. I have the machine making parts and am happy so far.
    Recently I set about getting the machine going with a bar puller to make some production parts. I have managed to get it running and doing the job easily with the excepting of the parts counter.
    I have changed the M30 at the end of the program for a M99 to loop back to the beginning. My parts counter works fine with a M30 . I cant find an M code to make the parts counter work. There is nothing in the Yang manuals .
    My understanding is it can also be done with a macro but I would like to use the counter if possible as that is what I use on other machines.
    Any help or suggestions greatly appreciated.
    Sep 2011
    3
    Re: Fanuc OT Cycle Counter
    If anyone can help me, I'd be very grateful. I'm running a bar puller and using a stopwatch to know when to stop the machine. It's going to bite me if I'm not careful!!
    My work counter functions with a M30. and counts up fine. When I replace the M30 with a M99 to loop the program it doesn't count. Understandable. I have another machine that uses a M12. That machine is a 18i and has a separate parts counter.
    My understanding is there is a parameter that will be set with a number to designate the M code. ie Parameter #?? is set to 12 so M12 is my counter M code. Please correct me if I'm talking rubbish.
    Control is Fanuc OT on a Yang ML25
Name:	Yang Screen.jpg
  1. Fanuc o-t parts counter
    By steer in forum Fanuc
    Last Post: 04-20-2020, 12:12 PM
  2. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  3. FANUC 0-MC cycle counter
    By FuddMcDee in forum Fanuc
    Last Post: 06-14-2012, 07:34 PM
  4. cent 6 cycle counter
    By smokie72 in forum Milltronics
    Last Post: 06-17-2011, 06:19 PM
  5. G52 w/ COUNTER on Fanuc O-M
    By bikebasher in forum G-Code Programing
    Last Post: 12-04-2008, 07:39 PM
