The #5555 pasword is a READ password. Fanuc has two passwords, READ and WRITE. Fanuc Ladder III requires the WRITE password. The only way you are going to obtain that is from the machine tool builder or you use an SRAM card so GETPASS can read it.
Send ur plc ladder to dilipgdw10@gmail.com
Send ladder to dilipgdw10@gmail.com
no ,you ca not use,will not fit inside the cnc controller,sram card is thinner
Hi guys,
I have a DMG DMC-63V milling machine with a fanuc 180i-mb.
There is an issue with one of my PLC outputs so I need to monitor the PMC Ladder to find out where is the problem. PMC Ladder has a password that I don't have it.
Can anyone help me with that?
i know all Mori machines use letter L to view the ladder
