How do I remove the error code 101 from a Robodrill Fanuc 16m Control?
Thanks.
Thanks.
Same as other Fanucs. in the setting page, type in PS101 then input.
The book Fanuc maintenance says: The power turned off while rewriting the memory by program edit operation.
If this alarm has occurred, press <RESET> while pressing
<PROG>, and only the program being edited will be deleted.
Register the deleted program.
If that fails then you will have to clear all memory and reload. Please make sure you have a solid backup of EVERYTHING in the CNC before clearing any memory.
