587,449 active members*
2,522 visitors online*
IndustryArena Forum > CAD Software > Autodesk > feature projection problem...
    Feb 2011
    92
    I'm new to Inventor and after many video tutorials, started trying on my own.
    I'm now stopped by a problem that a day of googling and looking into help and video tutorials didn't solve it for me...
    description:
    1. I have a part with holes, and one, without
    2. I want to transfer the hole of the first one to the next one on the right place
    3. Finally to cnc the parts and hopefully get holes with high precision face to face.
    That is, I want to project the hole from one part to the second part, after fix the first part on the second part using constraints, so that to have the right place for the hole.
    I can't figure out how to transfer the hole feature in the assembly environment, from one part, to the other.
    As you can see from the attached image, I placed the first part that has the hole, exactly the way needed to the second, but the technique of transferring the hole remains a secret to me, hope you help to open it :-)
    Thank you in advance for your kind attention.
    May 2008
    99
    Sorry for the delay.... just saw your post.
    1) Both parts are in an open assembly.
    2) double click on the back part ('block')to activate it in place.
    3) create a sketch on the front face of the block
    4) use 'Project Geometry' in the sketch and select the holes you want to project.
    5) exit sketch, and create a hole based on the center of the circle you just projected.
    6) return back to the assembly, and you will notice the block part now has an 'adaptive' icon next to it in the browser, meaning that it's dependant on the hole in the bracket part.
    Hope this helps. Adaptivity has it's place. Beware it can cause problems in assemblies with MANY parts, as the dependencies can get complicated quickly. At that point, there are better ways to do this. (Skeletal modeling)
    Feb 2011
    92
    Quote Originally Posted by tlharris View Post
    Yes that is the solution, exactly! Thank you very much for the step by step instruction! :-)
  1. projection with v23
    By TGSTP in forum BobCad-Cam
    Last Post: 04-15-2011, 09:08 PM
  2. Problem with linked feature
    By sk96_me45 in forum UG NX
    Last Post: 12-01-2008, 05:44 PM
  3. Artcam Feature problem
    By djh82uk in forum ArtCam Pro
    Last Post: 01-16-2008, 11:19 PM
  4. feature cam problem
    By MarshCustom in forum FeatureCAM CAD/CAM
    Last Post: 01-14-2008, 09:55 PM
  5. Projection
    By fooo in forum Mastercam
    Last Post: 10-17-2007, 03:28 AM
