603,363 active members*
4,246 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> TNC > feed per teeth- column cut is missing in TOOL.T.
    Hello community,
    I have a question regarding the tool library TOOL.T
    When I enter the feed FZ ( so per blade) then i get an error message that i need to enter the number of teeth into the column CUT.
    The problem is that can’t find a column Cut in the TOOL.T. What am i doing wrong?
    Thanks for your help
    Jul 2005
    99
    You can define the order of the columns in the machine parameter , an also if the non unused column are displayed or not.
    You need to have a look in the manual of the machine manufacturer what MP that is.
    Or save Mp back, open it in the editor and search for text (Cut)
    With best regards
    Mulder
    Ich bin nicht versaut... Ich nenn das moralisch flexibel!!!
    Hello Mulder_27
    yes super! I managed it!!
    Thanks for your quick answer and of couse thanks for the hint!
