603,936 active members*
4,166 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Feedback from Driver, how does Mach3 know where it is?
Results 1 to 4 of 4
    Oct 2004
    198
    Howdy peeps, just enquiring as to how Mach3 comunicates withe a servo driver to know it's position?
    From the driver I have inputs of STEP, DIR & ENABLE and an output of RUN.
    Currently when the drive trips the DRO keeps counting and the program keeps operating.
    I'm guessing I need to set the output of RUN as an input on the computer, I'm just not sure how I tell Mach3 to halt the program when it stops recieving a signal from the RUN terminal.
    Mar 2003
    35494
    Mach3 can't keep track of where your servos are. It just tells them where to go.
    It is poosible to write a macro that will read encoder signals and compare them to the commanded position. There is a commercial add-on product that does this at www.rogersmachine.net
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2004
    2849
    Well with the hobby type drivers you have an "open loop" system, it's never truly a "closed loop" system.....the system that ger21 references...alerts you when a discrepancy occurs and expects you to correct it........a "closed loop" system would be auto-correcting without manual intervention.
    Oct 2004
    198
    Thanks guys, I didn't realise that it is technically an open loop system, now I can understand why you don't need feedback from the encoder to the pc.
