603,957 active members*
3,319 visitors online*
IndustryArena Forum > CAM Software > Mastercam > feedrate for contouring using v9?
Results 1 to 6 of 6
    Sep 2005
    23
    i cannot remember how to get mastercam to output the correct feedrate for contouring.
    if you know what i mean for example going around circular arcs and adjusting the feed to match for the arc move to suit the centerline of the cutter.
    i do not remember if it was a edit in the post or if it was profiling the part using 0 cutter for cdc .
    anyone know off hand it has been awhile?
    Apr 2007
    8
    IT all depends on the material your are cutting. there's a place in your material defining page .
    Jan 2006
    4396
    Is there a setting in the Main SetUp like "Reduce Feed % around Arcs"? I believe there is, but can't quite remember where it is exactly. Try looking in the Material Properties like bmracing28 said and try the Main SetUp page. It has to be in one of those places.
    Cheers!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2006
    1013
    I think it's on the Job Setup Page. But....Dont bother with it. "reduce feed for Arcs" has never worked right. You'll get F0 output for feedrates.
    I put it into a post once. Had to calc the radius for the arc and apply the feed % formula.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Dec 2006
    247
    I agree with mike it has never worked as you would think, most controllers have a setting or parameter where you can set a percentage to reduce to.
    Read your manual and parameters or call the dealer.
    Joe
    Sep 2005
    23
    thanks i know it worked great.
    will have to look into it more.
  1. Help Need Help With 3d Contouring
    By D5PENNIES in forum Hobby Discussion
    Last Post: 04-03-2007, 02:24 AM
  2. 3D Contouring????????
    By cut2spec in forum Benchtop Machines
    Last Post: 03-18-2007, 07:08 PM
  3. contouring help
    By rbest27 in forum Surfcam
    Last Post: 02-02-2007, 04:14 PM
  4. 2D contouring with spiral
    By Alan L in forum Hypermill
    Last Post: 12-31-2006, 02:53 AM
  5. cutter compensation while contouring
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 01-30-2004, 04:21 AM
