603,874 active members*
7,664 visitors online*
Thread: Feeds/Speeds
Results 1 to 17 of 17
    Feeds/Speeds
    Ok, I have a few questions.
    I have typically only machined aluminum and I have no problems running that, but I need to be doing some steel too. I decided that tonight was a good night to start, and, I subsequently snapped off a .25" endmill.
    I was trying to machine a "step" into the jaws that came with my vise. I just wanted to do a slot that .15' deep. Normally, I do that in aluminum soft jaws, but it's a new vice and I don't have any soft jaws for it yet so I figured that adding a step into the jaws that came with the vise wouldn't be a big deal.
    That being said, here is what I looked up/calculated for feeds/speeds.
    Cutter Diameter: .25 HSS
    Surface Feet per Minute: 120
    Calculated RPM: 1833
    Number of Teeth: 2
    Chip Load: .003
    Calculated Feed Rate: 11ipm
    I tried doing a Depth of Cut of .05" deep.
    • What the heck did I do wrong?
    • How do I choose the SFM and ChipLoad accurately?
    • I've been using Whitney Tool I Speed and Feed Calculator for my feed/speed calculation and their only recommendation is .002 to .005 for chip load as a starting point.
    • How do I choose how deep of a cut I can make at one time? I was always told that you should take the diameter of your endmill and divide it by 3 and that is usually a safe number. Is this just for aluminum? I didn't think so, but it appears that my thinking is flawed.
    If someone can help give me a better understanding of feeds and speeds, I would be forever in your debt. Some of the values have been a guessing game with me and I'm tired of being frustrated with feeds and speeds.
    Also, does it mean that I should be able to double the RPM and double the feed rate?
    Thanks in advance,
    Wade
    May 2004
    4519
    I think you selected speeds and feeds for aluminum, not hardened steel, especially the feed per tooth with HSS tool. (I would never purposely butcher the stock vise hard jaws.)
    Jan 2012
    59
    1.What made you think you could cut hardened vise jaws with a HSS cutter.
    2.Just buy some soft stock drill and counterbore a couple holes soft jaws done
    As I stated, I typically have only machined aluminum with very little knowledge of steels of any type.
    If you look at the chart on the page I gave, all the settings are for steel. Apparently my problem was that they are not for hardened steel.
    As far as why I thought I could cut them, obviously, because I have never used them before, or HAD use for them before, and didn't realize they were case hardened. That would have been the end of my attempt for sure. All my parts used steps in the jaws, so it made sense to have them in the stock jaws.
    I'll update my question based on the info you guys gave me.
    IF I was using LOW carbon steel, and I used the setting above, would that actually be the correct feeds and speeds?
    Would I be able to double the RPM and the speed or would that just cause more problems? If it would cause more problems, how do you increase the speed of cutting, or don't you?
    Thanks,
    Wade
    Jan 2012
    59
    you have to stay within the SFM your cutter can handle
    for HSS in harden steel below 40RC dont go over 50 SFM
    If you have to cut the jaws use carbide and stay around 300 SFM
    .002 chipload
    Thanks a1diesinker!
    Can you give me an idea where to get at least some idea where to get SFM and chipload for various types of cutter out of various materials?
    Those are 2 tidbits of info I have yet to find good sources of.
    Thanks,
    Wade
    Mar 2006
    2712
    Cutter manufacturers such as Regal Beloit, Niagara etc.
    Dick Z
    DZASTR
    First of all, I found this chart, which, if it's accurate, should help me out a lot:
    http://its.foxvalleytech.com/machsho...edratecalc.htm
    And, here's another question.
    My old mill had a spindle speed of 3600 rpm and I was able to cut .100" deep at 18ipm with good clean results with a .25 endmill. I calculated that with a .0025 chip load in 6061-T6 but had to use a max SFM of 235 because of the max speed of my mill.
    Now that I have a spindle capable of 10000 rpm, does that mean I should be able to cut with the same cutter and a spindle speed of 10k at 45ipm?
    Here are the values I used in the Whitney feed/speed calculator listed in my first post.
    Material: 6061-T6
    Cutter Dia: 0.25"
    Depth of Cut: 0.1"
    SFM: 600
    Calc'd RPM: 9167
    Num of Teeth: 2
    Chip Load per Tooth: .0025
    IPM: 45.84
    Thanks,
    Wade
    Jan 2012
    59
    when cutting aluminum the only thing that will limit you is heat
    and adhesion.
    I cut 6061 with a 1/2 EM at 10000 rpm 50ipm all the time
    If I can get in the OKK I run 20000 and 100 ipm
    keep it wet and cool
    Ok, thanks a1diesinker. That helps a lot. All of my machining has been done at 3600 RPM, I almost feel like I'm starting over with my new machine and a 10K spindle.
    I just bought a Tormach 770, so it's a very new experience for me. Needless to say my lack of knowledge about the original vise jaws being hardened was an annoying first attempt with my new machine.
    Wade
    May 2004
    4519
    Get a copy of the Machinery's Handbook and study the section on speeds and feeds. Reference the tool makers recommendations. All other sources are suspect.
    Apr 2012
    40
    Check out G-Wizard's calculator, it is really dependable in my opinion.
    Sep 2012
    255
    Check out this calculation for the situation you have described
    FSWizard
    For a 0.05 slot in 45 rc steel you have to use 0.001 chipload
    Otherwise you will snap the endmill or chip the corners
    Your RPM should be around 1000 and feedrate 2.0 ipm.
    Generaly it is not a good idea to machine hardened steels with HSS tools. A carbide EM would do a quick job in your case.
    Btw FSWiz will recommend DOC depending on your endmill geometry and material being machined.
    It also considers length of the tool and other factors. I have yet to hear from anyone who broke anything using calculations from it.
    http://zero-divide.net
    FSWizard:Advanced Feeds and Speeds Calculator
    Awesome site Zerodivide.
    Thanks for the info too. I opted not to machine my hard jaws afterall, but now I at least know what I did wrong.
    I also found that doing a .16 DOC in aluminum my speed is only about 8 IPM as it starts to bog down a bit. I figured I can do something more like a .1 DOC and probably step my speed up to 15 IPM. It could also be that switching the type of endmill I use would help out a lot too.
    My Tormach 770 has a 1.5 HP motor. So far, i'm pleasantly suprised how nice it cuts and how quiet it is.
    Wade
    Sep 2012
    255
    Quote Originally Posted by a1diesinker View Post
    and adhesion.
    With flood coolant we run 1/2" 2fl carbide em's at 10000 rpm and 90 ipm. DOC depends on type of EM and length. But 0.25" deep for slotting with regular length generic endmill is a safe start.
    It will take almost 4 HP to make that cut however.
    When power is the limiting factor i think its better to reduce DOC and use proper chipload. You will get more tool life this way.
    Jul 2011
    218
    Quote Originally Posted by txcncman View Post
    I try all the time but I find it not very descriptive
    Also I have never had anyone properly explain it to me
    Ive gone over and over but does not make sense to me
    CHOCLATE? THIS IS DOODOO BABY!
  17. #17
    I'll be honest, the FSWizard shown above has been what I am looking for.
    It actually includes a calculated chipload and everything, as well as different tool types out of different materials.
    I really appreciate the link, and I'm sure you will too BoatDudeGuy.
    Wade
  1. Feeds and Speeds
    By tac8357 in forum Mentors & Apprentice Locator
    Last Post: 06-26-2008, 03:50 PM
  2. speeds and feeds
    By stevieboy in forum MetalWork Discussion
    Last Post: 03-09-2008, 03:55 PM
  3. Need some help with speeds & feeds
    By ldkell_2000 in forum MetalWork Discussion
    Last Post: 03-01-2008, 05:35 PM
  4. speeds and feeds
    By rodzilla in forum Benchtop Machines
    Last Post: 02-20-2008, 05:30 AM
  5. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
