603,832 active members*
4,678 visitors online*
    Nov 2020
    10
    Feeds and Speeds questions
    I am using the Shark Pro CNC machine alongside VCarve Pro 6.5. VCarve Pro has bit already loaded in and I can choose from those. My question is I would like to get this bit here:
    https://www.amazon.com/Yonico-31210-...33&sr=8-6&th=1
    It is a 1/8" endmill 2 flute upcut bit. Can I just use the default 1/8" endmill selection from inside VCarve Pro for the speeds and feeds or do those need to be changed? Thank you.
    Mar 2003
    35494
    Re: Feeds and Speeds questions
    V Carve's default feedrates are rarely ideal. Different materials, and different machines, even different holddown methods can require different feedrates.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2020
    10
    I am mainly using poplar wood with the above mentioned bit. Suggestions of feeds and speeds or would the default be good from VCarve?
  1. G0704 conversion - feeds and speeds questions for 0704 users
    By coyoteboy in forum Benchtop Machines
    Last Post: 07-25-2014, 11:40 PM
  2. Speeds/Feeds ... for a nub
    By thomax00 in forum MetalWork Discussion
    Last Post: 04-16-2013, 07:43 PM
  3. Help Please Feeds and Speeds
    By mtcnc in forum Uncategorised MetalWorking Machines
    Last Post: 01-21-2010, 10:36 PM
  4. Various 4340 Speeds Feeds Questions. Long Post
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 11-04-2008, 02:27 PM
  5. Feeds, Speeds & general questions
    By PEU in forum Syil Products
    Last Post: 12-13-2007, 07:49 AM
