588,030 active members*
4,300 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > Feel like an idiot, questions on limits, homing, offsets...
Results 1 to 6 of 6
    Feb 2009
    2143
    I discovered today my machine HAS homing switches, which is great! Got them working right. Taught myself how to set up soft limits, and have that working right.
    What I can NOT figure out is how to get consistent offsets to persist through powerups...
    After I set a new offset (hit Zero at X1, Y1, Z1 with respect to the homing machine position of 0,0,0) and hit "got to Zero", it uses the offset (it returns to machine position 1,1,1 - the new offset 0,0,0).
    HOWEVER, if I power off and back on (or just close MACH3 and reopen it), and rehome, the machine and offsets return to machine 0,0,0 (the 1,1,1 offset is lost).
    What am I doing wrong? I would like to have the machine home to machine 0,0,0, then reset the offset to a known value relative to that position, and set the offset 0,0,0 at that new position...
    Does that make sense? If so, can someone describe what I need to do to get the function?
    Jul 2007
    887
    I think you need to go to Config->General Config and in the lower right hand corner you tick the option Persistant Offsets. This will save the offsets when you exit. If you also tick the Optional Fixture Save it will, on exit, ask you if you want to save them.
    /Henrik.
    Feb 2009
    2143
    Thanks, I'll try those options.
    I do get the question if I want to save my fixture, and I reply yes, but not sure whether that is doing as it should/what I want/need.
    Mar 2003
    35538
    Hmmm, I replied to this last night, but no post???
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2009
    2143
    And what did your reply say?:stickpoke
    Mar 2003
    35538
    Same as Henrik's.
    Gerry
  1. HELP! Limits and homing are killing me!
    By stagefivedrift in forum Mach Mill
    Last Post: 10-26-2010, 04:37 AM
  2. Need Help with homing and limits
    By ratpack in forum Mach Plasma / Laser
    Last Post: 04-28-2010, 05:31 AM
  3. Homing and Limits Setup
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2009, 04:12 AM
  4. Feel like an idiot but....
    By fretsman in forum Videos
    Last Post: 10-05-2008, 06:21 PM
  5. How homing and limits work
    By SyilAmerica in forum Syil Products
    Last Post: 11-14-2007, 08:55 AM
