Originally Posted by
Kawgomoo
The reason i am chasing the "2 ohms" across the legs is because ohms law tells me that 2ohm coil on 220v source is going to pull 110amps. This is more than the plaque states for max amperage of the machine, therefore in my mind. Its a problem, or at least worth exploring. The next lowest resistance i can find is 44ohm across the legs which works out to like a 5 amp draw, which seems more in line with what id expect to see.
As i said. I don't really know what I'm doing here. Just poking around with a meter and attempting to formulate some understanding of what the hell is going on inside this cabinet. Definitely over my head currently.
