587,762 active members*
3,349 visitors online*
Results 1 to 1 of 1
    Sep 2006
    33
    Fibre Laser Marking Machine
    Wuhan Huagong Laser Engineering Co.,Ltd is a high-tech company which is always been at the leading edge of the R&D of laser technology and its application in China and has become the authoritative supplier for the holistic solution of laser processing."HGLaser" leading product covers complete power series including Laser Cutter Series, Laser Welder Series, Laser Marker Series, Laser Texturing Equipment, Laser Heat Treatment Series, Laser Tiny Process Series, Medical Operation Laser Equipment,solid& gas Laser Equipment, Laser Parts etc.
    Fibre Laser Marker (LSF10)
    Product Introduction:
    The optical glass fibre laser marking machine has a homogeneous structure, any optical soiling, any power coupling losses and it has an air cooling system. In contrast to other laser machines, this laser machine has a high efficiency and reliability. Efficiency and a long duration of usage are the main arguments for customer’s choice and usage of this optical fibre laser marking machine.
    (Pictures: Standard optical glass fibre laser marking machine, luxurious optical glass fibre laser marking machine
    Essential features:
    The laser beam has an excellent quality
    Low running costs
    This laser machine has a long duration of life
    This laser machine has an exquisite volume and it is suitable for adverse circumstances
    Application Fields:
    -electronic components
    -Electronically products
    -IT industry
    -automobile components
    -metal tool production
    -precision machines
    -gifts and jewellery
    -medical instruments
    -electrical altimeter
    Specification:
    Type-number:
    LSF 10 LSF20
    Average Output energy:
    10W 20W
    Laser wavelength:
    1064nm
    Pulse repeated frequency:
    20-80 KHz
    Marking depth:
    0.01-0.2mm
    Smallest line width:
    0.01mm
    Energy supply:
    100V-240V (single phase 50Hz)
    Main engine size:
    550x290x570 (mm) (standard)
    Beams qualityM²:
    1.4-1.8
    Maximal straight line marking speed:
    7000mm/s
    Marking Surface:
    Φ70 (standard), Φ100, Φ175 (optional)
    Repeated precision:
    0.2µm
    Smallest type size:
    0.2mm
    Energy consumption:
    <500W (excluding computer)
    Cooling system:
    air cooling
    www.hglaser.com/english
    [email protected]
    tel:86 15994288030:rainfro:
    Attached Thumbnails Attached Thumbnails 200711217554296.jpg   fibre.jpg   fibre2.jpg
  1. CNC filament winder(carbon fibre)
    By wallygator99 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 10:49 PM
  2. Routing Carbon fibre laminate
    By kong in forum Composites, Exotic Metals etc
    Last Post: 04-09-2007, 05:08 AM
  3. steel fibre??????
    By the4thseal in forum MetalWork Discussion
    Last Post: 12-06-2006, 07:53 PM
  4. Marking a degree wheel
    By tafc in forum MetalWork Discussion
    Last Post: 09-16-2006, 03:46 PM
  5. Simple CNC marking/writing apparatus?
    By kywoodwrkr in forum DIY CNC Router Table Machines
    Last Post: 03-03-2005, 03:58 PM
