603,316 active members*
1,893 visitors online*
    Jun 2006
    48
    Question Fidia M20.f g-code help
    I'm preparing g-code to run on Fidia M20.f control, and would like to add some comment lines in beginning of the code, but don't know the correct syntax for comments, so that the machine would ignore those lines?
    Jul 2019
    Re: Fidia M20.f g-code help
    hi if you put comments in ( ) it will not read it as code hope this helps
