603,970 active members*
2,030 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > figured out the hardest part first, now building can begin
Results 1 to 10 of 10
    Jan 2004
    490
    I have had some Igus sleave bearings in my garage for months, trying to figure out a holder for them. Almost decided to save my pennies, and just buy some from them at $11 a pop, when an idea hit me! machine 3/4" pipe, and weld channel to it! So simple it is great, and works awesome too! Here is a pic.
    Stop talking about it and do it already!!!!!
    Jan 2004
    490
    another photo. Machine will be built out of steel tubing, 1" by 1", with 1/4" plate here and there to facilitate mounting of steppers, lead screw bearings, etc. Tubing is only .080 wall, but will be assembled in a space frame design, with triangulations for strength.
    Jan 2004
    490
    This is the slotwall that I will be using. Got it for free at Blockbuster video. It measures 4' by 2', so that is what the table will be. It should fit underneath my workbench quite nicely, with castered wheels to roll around my tiny garage. May also work on a high speed spindle idea I have had for months now, utilizing a modified pneumatic die grinder. That will have to wait though.
    Jun 2003
    167
    Not bad, Not bad at all. Nice low tech solution. Ron
    Jun 2004
    44
    your going to need one hell of a compresor to run a die grinder for
    hours on end
    Jan 2004
    490
    No, no, no...cut the housing, and pare it down. Remove the impellers from the shaft, and replace them with a pulley, step or otherwise, then run with a small electric motor. The only reasoning behind the die grinder, is to get the collet, shaft, housing, and bearings for $12.
    Jan 2004
    490
    I have had the thing done to this point for a few weeks, just haven't hd the time to post about it. Here are some more photos.
    Jan 2004
    490
    I have had the thing done to this point for a few weeks, just haven't hd the time to post about it. Here are some more photos. The drawer slides have been modified a lot to give 3.5 inches of very solid travel, in a total length of 9". Let the barage of questions begin!
    Attached Thumbnails Attached Thumbnails Machine1.jpg   Gantry1.jpg   Drawer slides.jpg
    Sep 2003
    1113
    Quote Originally Posted by Hobbiest
    Sure do liike the sound of this implementation! How are impelllers fastened to the shaft? Send along some picks with an idea of how well its worked out. Motor sizing (weight/power) and availability I suppose are the biggies.
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Jan 2004
    490
    Haven't gotten that far with that idea yet.
  1. Beginner moldmaking questions
    By fastturbovet in forum Moldmaking
    Last Post: 06-23-2005, 09:38 PM
