587,218 active members*
2,612 visitors online*
Results 1 to 4 of 4
    Mar 2004
    636
    File Conversion
    Would anyone be so kind as to convert a file for me? I am drawing up a machine in Alibre Design (personal edition v12) and need a drawing of a hiwin linear bearing. I have found it in many formats, but not one I can load into my version of Alibre. I have attached an stl version hoping someone could convert it for me. Ideally an Alibre Part file format.
    Thanks to all and Merry Christmas.
    Dan
    Check out what I am working on at www.routerbitz.com!
    Jan 2007
    1795
    Re: File Conversion
    you should be able to use a dxf vectorfile
    this is a stl file what is a 3d model..
    simply don't worth to work with, because too hard to derivate the dimensins of
    if you want to work with anyway, then download meshmixer, and export as obj format..
    on hiwin site you can find many pdf
    your program could open it
    if not then download inkscape, and inkscape can convert ti to dxf or eps....
    HG / HGL Series Super Heavy Load
    Jun 2006
    3063
    Re: File Conversion
    Try importing a STEP or IGES model of the bearing - Alibre should be able to read one of those. STEP would be preferred, I think. I'm on a later version of Alibre (now known as GeoMagic Design) or I'd try to convert it for you.
    Nov 2012
    46
    Re: File Conversion
    It may work going backwards,
    When exporting into Cut2d I use Anycad Exchage 5.0. on the exported stl files. It gets me a starting layer so I guess you could try using Alibre's import feature.
    http://www.anycad.net/the-free-3d-mo...xchange3d.html
  1. File conversion please?
    By hello! in forum Solidworks
    Last Post: 06-02-2014, 04:09 AM
  2. dwg to stp file conversion!
    By PTdesigns in forum Uncategorised CAM Discussion
    Last Post: 06-16-2011, 09:10 PM
  3. dwg file conversion
    By Hiredgun in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2008, 02:08 PM
  4. file conversion
    By chuy in forum Mastercam
    Last Post: 09-02-2008, 04:13 AM
  5. File conversion help please
    By studysession in forum Uncategorised CAM Discussion
    Last Post: 10-03-2007, 01:12 PM
