603,348 active members*
3,074 visitors online*
Results 1 to 4 of 4
    Jan 2006
    67
    Question File/Save as seperate
    Scott,
    I'm trying to use File/save as seperate to breakup a large backup file. So far have had no success. The file is from a Fadal CNC 88HS downloaded using Fadal Assist. The output looks like this:
    n1o1(part # op#
    n2t1m6
    M2
    n102(***
    m2
    n1o2000(***
    m2
    are the n words in front of the o word a problem?
    maybe the (program description?
    any ideas?
    Thanks,
    Dave
    Mar 2003
    765
    Dave,
    Yes, NCPlot is looking for the program ID in Fanuc format. The O word must be the first character on the line:
    O1234(PROGRAM1)
    G1X...
    M2
    O2345(PROGRAM2)
    G1X..
    M2
    Is the N word always the same when it appears in front of the O word? If so, you could do a search/replace to remove it before using the Save as Separate tool.
    Regards,
    Scott
    Jan 2006
    67
    Worked great
    Thanks,
    Dave
    Mar 2003
    765
    Quote Originally Posted by daking
    Worked great
    Thanks,
    Dave
    Cool, glad I could help. :banana:
    Scott
