Hi All,
Got a simple fillet edge problem (file attached). Trying to fillet the top edge of a 8 sided figure. Fillet works fine if the sides are 90 degrees to the CPlane. Mine are tilted inward 30 degrees from the vertical. This results in a sharp spike at each corner and in addtion, the fillets are open at the corners. Any ideas on how to fix? Thanks in advance.
ChuckInCR
