Finally broke down, droped the $2100 and bought a hypertherm45 with machine torch for my plasma table. Up until now ive been using the everlast plasma. The everlast kept losing arc, going through consumables rediculously fast, and giving bad readings on tip volts so my DTHC was useless.
Let me just say it this way, 100000% improvement from the everlast. There is no comparison. Jim from hypertherm is dead on with his posts, the cuts are perfect...no slag. Theres no losing arc-ok signal, no loss of arc, no going through a tip in 5 mins of cutting, etc. The hypertherm just works! Cut quality is very good and consistant throughout the cut, but like i said, the most important thing to me is there is no no problems with the cut that interrupt it.
That said, for the money, if you want a machine for hand cutting (not cnc), the everlast for ~ $700 is priced so low you cant go wrong. Its not going to work like the hypertherm but its a good machine for $700.
Candcnc has all the settings setup in it allready for the hypertherm! I basically just mounted the torch, and used the settings in the book that comes with the hypertherm in sheetcam. Perfect cut, first time! The fact that it comes with a book with amps, torch height, torch volts, etc for just about every material is priceless. These guys did their homework.
Looking at the consumables you can see right away, its a HUDGE difference from a Chinese machine....pics below.
Hypertherm tip on left, everlast/harbor freight/Chinese on the right.
The torch mount I made out of 1.5" alum square solid. Took me all day, (It was a 2 hour job, but it was one of those days...break taps in material, break drill bits, etc....grrr!).
The EXCELENT manual that comes with the hypertherm, shows settings for everything! AWESOME.
There is is, in its glory under my water table.
The first cut i did with it, 1/4" Aluminum. Almost perfect. Like Jim always says, there is no slag. Basiclly there is just an edge left that u can scrape off using a sharp object.
