603,890 active members*
4,542 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Finding self intersecting geometry
    Oct 2006
    16
    Unhappy Finding self intersecting geometry
    I'm trying to create a loft, everything looks fine, but SW is giving me the "self intersecting geometry" error.
    Is there anyway for SW to show me where it is, or how do I find it? I'm working off a DWG file and it's getting extremely frustrating.
    If anything is there a way to "trace" the lines of the dwg file into new sketch planes?
    Thanks,
    Matt
    Mar 2003
    35494
    Quote Originally Posted by MetropolisCNC View Post
    Thanks,
    Matt
    Change the file type in the Solidworks Open File dialog, and you can open the .dwg file in Solidworks. Choose the option to import into a new part, and it'll open on a sketch plane.
    Can't help you with the first problem.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    1660
    Intersecting geometry is often found where it crosses over itself. Check the geometry and see if this may be the case.
    You can move geomtry from one plane to another [parrallel] plane by using 'convert entities', it's in the sketch tool-bar as well as under sketch tools [IIRC]
    J
    JerryFlyGuy
    The more I know... the more I realize I don't
  1. geometry
    By ticko2 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2009, 11:15 PM
  2. geometry
    By Htech in forum Fanuc
    Last Post: 12-09-2007, 06:25 PM
  3. self intersecting error What The
    By Prboz in forum BobCad-Cam
    Last Post: 05-31-2007, 01:31 PM
  4. Geometry from solids
    By GigaHz in forum Surfcam
    Last Post: 04-17-2007, 10:58 PM
  5. Geometry from NC
    By rherman in forum BobCad-Cam
    Last Post: 09-21-2006, 01:10 PM
