588,562 active members*
4,630 visitors online*
    Jul 2005
    86
    Fine-cut consumables - 1/4" mild steel
    Using fine cut consumables
    Hypertherm 1000
    1/4" mild steel
    Nozzle 220329
    I know these consumables are designed for thinner materials but...
    What parameters are you using?
    Ipm =
    cutting height above material =
    amps =
    psi (air) =
    pierce height =
    pierce pause (delay) =
    Dec 2008
    12
    Energy, what type of part design are you trying to cut w/ the finecuts?
    Below is the charting one should follow for the fineCut consumable set.
    The biggest problem you will run into w the fineCut consumables on this unrated thickness will be the pierce damage to the nozzle. If you were edge starting you could most likely acquire a very nice cut with a chance of much less consumable life at about 50 amps.
    https://www.hypertherm.com/library/files/Product%20Information/FL_880300_FineCut.pdf
    Dec 2008
    12
    Have you had any feedback or luck trying this out ?
    I am tempted to try this out if I can find some free time in our lab.
  1. kerf width using fine cut consumables
    By patriot customs in forum Waterjet General Topics
    Last Post: 05-17-2010, 05:36 PM
  2. Hypertherm and "Fine Cut" consumables
    By alliance_metal in forum Waterjet General Topics
    Last Post: 12-10-2008, 09:48 PM
  3. VF-2 Cutting 1/4" Mild Steel plate
    By akedward in forum Haas Mills
    Last Post: 11-25-2007, 01:05 AM
  4. Cutting 1" Mild Steel
    By 3DSteve in forum Waterjet General Topics
    Last Post: 06-14-2007, 10:58 AM
  5. RFQ - on 1/2" mild steel plate
    By BullCreek in forum Employment Opportunity
    Last Post: 07-11-2006, 12:31 AM
