588,159 active members*
4,687 visitors online*
    Apr 2009
    149
    Finishing process
    How do you get all the tiny lines sanded out of the routed image? Routed details are usually too small to sand by hand in a reasonable amount of time. What if you are making cabinet faces and need to sand out 10 flourishes? There's got to be a better way. Accents and flourishes I buy from suppliers are highly detailed but no router marks. How is this done?
    Sep 2007
    56
    Lines
    Its done by using a smaller stepover when routing. once you get above 8% or so stepover, it becomes more pronounced. The bigger stepover makes each part take less time to machine, but more time to finish.
    I make parts for a local hardware store....and they are happy with a 15% stepover. They are painting them and I guess the paint fills it in. When I do what I call stain grade, I get to under 5% stepover (on a .125 mill this is about .00625) and I get a smooth finish where lines can only be seen under a magnifying glass. On something I want to have absolutely no cleanup, I run
    .001 stepover. Comes out slick as glass.
  1. I am trying to learn this process
    By cob in forum Vacuum forming, Thermoforming etc
    Last Post: 04-11-2009, 05:46 PM
  2. Software Process
    By Ang_Panday in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-15-2008, 12:37 AM
  3. Software Process
    By Ang_Panday in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2008, 12:31 AM
  4. In the process
    By Smitty911 in forum Dolphin CAD/CAM
    Last Post: 05-10-2007, 06:34 AM
  5. Tig Process ??
    By millman52 in forum Welding Brazing Soldering Sealing
    Last Post: 04-30-2007, 07:41 PM
