... I think I generated more questions that the ones I figured out
Preface : Beginner, working with a humble Grizzly mini-mill. After tinkering around for a month or two, I built a little homebrew flood cooling system and prepared for some precision work.
My goal at hand was to machine a block of aluminum to 0.751" wide, on a bar 0.5" thick, ~4" long. At the end of the day, I got it to < +/-0.001, but man did I come up with some issues.
Issue 1 : How flat is my milling table? I trammeled (sp?) my table with the vertical head. Using a dial indicator with 0.0005" gradations on the spindle, I was able to seemingly get both ends of the table to <= 0.001". I spent a ton of time rotating that thing back and forth and I can't imagine getting much closer with the tools I have to work with. Now the weird part - if I run the dial indicator on the right half of the table, it stays within that 0.001". However, once I cross over to the left half of the table it starts to diverge quickly. Several thousandths over the 5 or so inches I can measure. What gives here? First off - is this level of precision normal for a low end mill? Second - what might be the cause of one half of the table to run out so much while the other half stays pretty even?
Issue 2 : How flat is my vice? I've got the low end crappy Grizzly vice. When I snug that guy down on the "good" end of the table, the run out is severe. Multiple thousandths over 2+" of horizontal travel. The only solution I could come up with was to fold over a piece of paper under the low side to raise it up a bit and then adjust the tightness on the T-nuts until it ran pretty close. Clearly, this is not a great solution. A vice that lousy isn't particularly usable. Is there a fix for this? I tossed around the idea of milling the rails of the vice myself, but I'm not entirely sure it's ready for potential destruction by me I'm not entirely opposed to buying a higher end vice, but I'd like to be sure there's actually a problem with the vice and not the user. Any advice?
Issue 3 : Parallelism. Even though I got my bar darn close to the desired dimension, one side is ever so slightly non-parallel to the other. If I stick it in the calipers, one side is flush, the other is just a hair off. In theory, if I endmill one side, then if I flip it over on to a perfectly flat working surface, endmilling the other side should result in perfectly parallel surfaces, no? I'm assuming this isn't working for me because I don't have a great technique for mounting the piece perfectly flat. I'm laying down two parallel bars on the base of the vice and balancing the workpiece on them as I tighten the jaws. But it never feels very snug. When the jaws tighten against the workpiece, the parallel bars get tilted ever so slightly. I can adjust and readjust, but it never quite comes out right. The end results confirm this. Anyone have any suggestions on getting things nice and flush?
Issue 4 : Backlash. My mill has some serious backlash that results when I tighten down the table motion screws. This is particularly evident on the vertical feedscrew. If I fine adjust right where I want, as soon as I tighten the motion screw, I'm looking at up to several hundredth's of an inch of offset. This is present on the horizontal feedscrews, but not quite as pronounced. The only thing I could come up with to get by this was to pre-tighten the motion screws right before I reached my range and then crank the feedscrew from there. This works fairly well, but it feels very much like a bad thing to do. If the motion is locked down, I'm putting a ton of stress on things as I force the feedscrew around. What the heck is the solution here? The feedscrew is accurate enough, but locking it down when done just blows any precision waaaaay off. I had to make 4 passes over the piece to get it down from 0.865" to 0.751", since each time wasn't quite where I thought I'd end up.
Welp, there's my questions. I would really appreciate expert advice here. I had a hoot cranking this thing out today (particularly since I got to see the flood cooling in action - VERY neat), but it felt very "hacky" instead of like truly precise work.
