587,303 active members*
3,425 visitors online*
    Mar 2016
    First build down to bob an driver wireing need help
    I have a mach3 interface board ver 1.1 and bl -tb6560 v2.0 driver board. i need help on how to tire the the two together. i have looked all over an have not come across any diagram. any help would be apprenticed . hope i posted i the right section
    Oct 2012
    179
    Re: First build down to bob an driver wireing need help
    Your motor drivers should have 2 power connections and 4 connections for step and direction. Either the + or - will be common and the other two will direct your step and direction. Your board and driver documentation should spell this out.
  1. Wireing (460 to220 volts)
    By hunterpowered in forum Bridgeport / Romi Lathes
    Last Post: 03-26-2012, 10:32 PM
  2. WIREING HARNESS
    By AB PRODUCTS 1 in forum Haas Mills
    Last Post: 09-30-2010, 07:29 PM
  3. wireing so far
    By stk2008 in forum CNC Machine Related Electronics
    Last Post: 09-17-2009, 06:19 PM
  4. Can anyone help me with some wireing
    By SCOTTY in forum CNC Machine Related Electronics
    Last Post: 07-22-2005, 12:07 PM
  5. wireing for mini lathe
    By SPEEDRE in forum Mini Lathe
    Last Post: 02-28-2005, 04:09 AM
