Hey guys, well been asking questions and lurking around, basically building a decent sized 3' x 5' table, everything so far has been bought at the local ACE Hardware, Home Depot and True Value Hardware stores. Basically i used mainly 3/4" MDF, and the skate bearing design with a few modifications of my own, the gantry has 2 sets of bearings on each side, the top set is bolted into place, and the bottom set can be adjusted to allow for some tension to be applied to the rails, and the gantry is really solid, and doesn't seem to rack, and it moves very freely.
Here is my next question. I am at the point where i need to order my ACME rods and motors, controller, ect.
Can i get away with a Nema23 sized motor, say something that puts out 425 oz-in of holding tourque, its a dual shaft bi-polar motor from kelling, (they are super close to where i live), for the X-axis, and something similar for the Y-axis. The reason i ask is because it would save me some cash if i could get away with a single motor on the X. I plan on using ACME Rod, with a .500" per Turn, ect.
Any info or wisdom is always appreciated.
