603,365 active members*
3,357 visitors online*
Results 1 to 11 of 11
    Apr 2006
    169
    first cnc and my first catia design
    Hi all my first cnc and my first catia design
    comment are welcome
    more sketches are coming
    Apr 2006
    169
    Router 3 hp work area x= 650 mm y =650 mm z= 200 mm
    It will have 2 work surfaces deep and flat
    Apr 2007
    1955
    Hello Hesham - I am enjoying looking at your project. First, I am very much just a beginner / forum reader, but it might be possible to make some small design changes which simplify the construction, and might even make it more rigid.
    Your uprights as designed will require carefully cut lengths and angles on a number of parts. It might be easier if you just make the entire uprights area out of a simple box frame. In other words, instead of making a sort of angled legs going up, just make a square frame, and mount it as needed to the X axis bearings to get the range of motion vs stiffness trade off right for your design.
    If you keep this idea going a bit further, consider making the Y gantry also a box frame, and make the Z / router sit entirely within this box. This is slightly less elegant looking, but should be quite stiff, and I would think, simpler to build. You are working with a 3 hp router, which is quite a bit more lively than the dremel tool / 8mm collets common to more flexible designs.
    While I am busy making suggestions about things I just barely know myself, please consider the idea of supported rails instead of just some rods. This will let you take the rail mouting all the way out to the main frame pieces, instead of mounting it on the extra angle pieces you are showing.
    Ok, time for me to pay attention to my own design shortcomings. Good luck.
    Apr 2006
    169
    Hi Harryn
    All the gantry is 4x4 box frame 3mm thickness
    The rails is 20mm Stainless Steel with Linear Bearing 20mm
    The aim of this design
    1 - the ability to disassemble the machine easily
    2- the ability to use 2 work surfaces deep and flat the deep surface well be equipped with Cooling pump
    These is the best design I can do for Egypt no rails or supported rails and the
    Precision Machining is a myth:drowning:
    Attached Thumbnails Attached Thumbnails 22.jpg   Shoot2.jpg   Linear Bearing.jpg
    Apr 2007
    1955
    Hi - it is a nice design. The first time I looked at it, I missed the very clever design which allows for two different depth locations for mounting parts.
    My main suggestion is:
    - The part of the machine in blue, especially the sides of it, are sort of a complicated, offset ladder shape. I personnally could not build this, but perhaps you can.
    - I think it will be easier to build if you alter the sides to look like a simple ladder shape - a bit wider at the base to cover the entire required width of the uprights.
    - If you add one more cross member at at the top to make it sort of a "stick frame box structure", then it will be really stiff.
    Apr 2006
    169
    :drowning:
    Mar 2004
    1306
    What are you intending to cut? Those unsupported rails will deflect and vibrate.
    Why make the side supports and back welded tubular structures? It would be a lot easiler to make them from solid plate material.
    How are you intending to keep the two Y axis motors synchronized?
    Regards,
    Mark
    Apr 2006
    169
    Hi Mark and harryn
    the tubular structures will be more rigid in welding and lighter It will be 4x4 box frame 3mm thickness the rails is 20mm Stainless Steel as u can see in the design I put two in each Side of the x axis to avoid DEFLECTION it will be looked by a nut
    Until now I did not start To cut anything except the Stainless Steel rails they are as follow
    4x90. 2x80 .2x40 if I can find Open Bearing I will re design the machine to supported rails type
    For the(( two x axis motors synchronized )) I think the software can slave too drive as one
    thx
    Apr 2006
    169
    after some up and down i have restarted my dream
    i Found a Laser Cutting shop in cairo
    and redesign the machine in SolidWorks
    [ame="http://www.youtube.com/watch?v=odHmvsHKEUs&feature=g-upl&context=G294140dAUAAAAAAAAAA"]cnc_TEST.mp4 - YouTube[/ame]
    Mar 2007
    46
    nice work man yes great work
    i know hesham have big idea about cnc machine lathe and many more
    cant do somthing randomly
    Apr 2006
    169
    diy cnc files
    SolidWorks 2011 STEP dxf
    https://grabcad.com/library/diy-cnc--1
  1. catia
    By Rich05 in forum Uncategorised CAD Discussion
    Last Post: 12-25-2013, 06:50 PM
  2. Catia v5 r17 Part Design and sketcher
    By KS Cowboy in forum Uncategorised CAD Discussion
    Last Post: 12-25-2013, 06:43 PM
  3. From Catia Design To Finshed Product
    By ashishg04 in forum Uncategorised CAM Discussion
    Last Post: 08-03-2007, 03:37 PM
  4. Catia
    By forrey45 in forum OneCNC
    Last Post: 07-16-2007, 11:15 PM
