603,783 active members*
2,686 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > First Impression Homann Designs Shuttle Pendant
Results 1 to 6 of 6
    Oct 2008
    2205
    So far I like it.
    https://youtu.be/tUX7pP3aLE8
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2205
    Re: First Impression Homann Designs Shuttle Pendant
    As near as I can tell this is basically a repackaged ShuttleXpress, but the packaging as a pendant is much more suited to the way I use it. My concerns or desires are noted in the video. My way isn't necessarily the best way, so if you see some way you think it could be better let Peter know what you would do. He is going to do that he thinks is best or will sell best. Not necessarily what you or I think is best, but he might not think of the little things you or I do.
    Bob La Londe
    Quote Originally Posted by Bob La Londe View Post
    So far I like it.
    Hi Bob,
    Thanks for the review. Addressing a couple of your questions:
    1. Step Button. I agree with your assessment that changing the jog step is not really required as coarse movement is done with the speed wheel, with the fine movement done with the jog dial. I leave it at 0.01mm.
    I could remove the button, but the intent was to make it compatible with the ShuttleXpress as it can also be used with other CMC software such as Mach 3/4, CNCDrive, LinuxCNC, Centroid Acorn, etc. The plan is to make stick on overlays to relabel the buttons.
    I could put an internal jumper that disables the step button. That would give the user the choice.
    2. Axis selector switch: - I thought about putting an axis selector switch in place of the four axis selection switches. The issue is that if the switch hold the input in the on state, it means that the selection of the axis can’t be done via the touch screen or display.
    If there is demented for it I can certainly provide that configuration.
    Essentially the goal was to make the pendant as compatible with the ShuttleXpress as possible.
    I’m also planning to sell just the ShuttleJogger dial so people can make there own pendants, or mount the dial into an existing control panel.
    Attached Thumbnails Attached Thumbnails IMG_1950.jpg   IMG_1952.jpg   IMG_1954.jpg
    Homann Designs - http://www.homanndesigns.com/store
    Oct 2008
    2205
    I had not thought about the touch screen as I don't use one. Of course you have to think about all possible customers. Not just one.
    I'll let you know if I think of anything else, or run across any problems.
    So far the video has about 60 views each on Yotube (67) and on Rumble (78).
    Bob La Londe
    Feb 2020
    10
    Are these for sale?
    Apr 2013
    1780
    How well sealed is it to prevent the entry of chips (a ShuttleExpress is awful!)?
    Agree that the step increment button should be omitted or at least able to be disabled. LEDs showing selected axis would be nice.
  1. Homann Designs - wonderful service
    By RCaffin in forum Australia, New Zealand Club House
    Last Post: 08-16-2021, 04:26 AM
  2. Homann designs gone Bust?
    By johnnyfp in forum Australia, New Zealand Club House
    Last Post: 07-30-2012, 09:52 PM
  3. Homann Designs Geckodrive Distributorship Sale
    By phomann in forum News Announcements
    Last Post: 02-21-2011, 07:20 AM
  4. Homann Designs MP-03 with a NM-200s2
    By JoeBean in forum Novakon
    Last Post: 11-20-2010, 03:06 PM
  5. Anyone know what is doing with Homann Designs?
    By netboss in forum Complaints and Praise Discussions
    Last Post: 05-20-2009, 02:08 PM
