588,165 active members*
4,038 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > First Job On My Router - Cool Cross
Results 1 to 5 of 5
    Sep 2009
    160
    My wife and I first saw this cross design hanging from the rear view mirror of a taxi in Honduras a couple of years ago. We later bought a couple of the same design crosses when we saw them in a gift shop in Belize (same cruise).
    I continue to be fascinated by the design, and at first cut out about ten of them on my bandsaw. I gave them away to friends and grandchildren – but that was quite a job. Then I said to myself, “Self, what a perfect job to prove out the new (self-made) CNC router.” I have no cad ability, so I decided I would program it directly in G code, trying to remember some skills I had a long time ago. Well, the tenth time was a charm – at least as far as I am concerned.
    Here is the the CNC result made in .220 inch thick plywood...it measures about 4.5 inches wide by about 5.5 inches tall. I used double sided carpet tape to hold the plywood to my spoil board. The plywood was cheapo luan, so not the best material, but it was more to prove out the code. I think I will try it next in cherry or something like that.
    The text file below is based on using a 1/8 inch end mill, 2 flute down spiral, at 10 ipm and 16000 rpm. I broke an endmill at 50 ipm, so I backed the feed rate way down. This file will cut down to a minus Z of .230 inches. I have decided that manual programming is not that much fun, so this may be my first and last manual G code file.
    My CNC uses 380 oz in motors, Gecko 540, and Mach3 for reference. These make good gifts for friends – and everyone else, too. Feel free to use the file for non-commercial purposes. Hope you enjoy.
    Angie
    Jesus6.TXT
    Mar 2003
    35538
    Hey, I'm going on a cruise to Honduras and Belize in Sept.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2004
    305
    Nice job on that project. Boy, and programmed by hand. That must have taken some time. I think that the last time I wrote an actual program by hand I was in school ten years ago. Now a days though, I wouldn't trust myself to write something cuttable... I would likely make a lot of scrap and some broken bits.
    Apr 2009
    5516
    Excellent! Thanks for sharing, these are going to make great gifts!
    Sep 2009
    160
    Forgot to mention that last pass leaves tabs on both sides of the big "S" to help hold cross into place. So you need to cut through those to release cross and then trim the remainder of the tabs off.
  1. Craftsman router collet cross reference?
    By johnmac in forum DIY CNC Router Table Machines
    Last Post: 12-12-2008, 10:08 PM
  2. Cross between CNC Milling Machine and CNC Router
    By desman in forum Commercial CNC Wood Routers
    Last Post: 04-27-2008, 03:47 AM
  3. lathe cross section
    By camtd in forum Mastercam
    Last Post: 01-31-2008, 03:43 PM
  4. cross slide
    By nantz in forum Benchtop Machines
    Last Post: 07-13-2006, 12:09 AM
  5. MOd for the cross slides
    By cncadmin in forum Benchtop Machines
    Last Post: 04-20-2003, 05:47 AM
