603,942 active members*
3,653 visitors online*
Results 1 to 9 of 9
Hybrid View
IM_MOOSE First time looking for advice 04-05-2004, 03:07 AM
DDM Check out some of the posts... 04-05-2004, 06:31 AM
IM_MOOSE ok awesome thanx -Clint 04-05-2004, 12:09 PM
teilhardo I saw an interesting design... 04-05-2004, 09:43 PM
IM_MOOSE you dont happen to have any... 04-06-2004, 01:29 AM
teilhardo I'll look through my "show... 04-06-2004, 02:01 AM
IM_MOOSE thank you very much 04-06-2004, 02:04 AM
DDM if you get onto ESAB's... 04-06-2004, 05:13 AM
IM_MOOSE thank you for your help Carl... 04-07-2004, 02:08 AM
    Apr 2004
    5
    Hey guys im looking at building a small CNC plasma table
    im looking for a cutting space of 2' x 3'
    wondering if any one has simple indepth plans
    and good advice
    any advice would be great thanx
    -Clint
    Nov 2003
    181
    Check out some of the posts on the DIY Wood routers forum, Same basic design only you don't wan to make it out of MDF . Probably make a moving gantry style system which is what just about every cnc plasma cutter uses. I'm not sure what else to tell you. Check Ebay for ideas.
    Carl
    Apr 2004
    5
    ok awesome thanx
    -Clint
    Jun 2003
    195
    I saw an interesting design at a trade show in LA a few weeks ago. It has the normal frame made out of steel beams but the motion system used a rack and pinion instead of expensive ballscrews and friction producing leadscrews. I don't think that it will have the accuracy of the above-mentioned devices but it will definetely be cheap!
    -Please check out my webiste-
    http://www.teilhardo.com
    Apr 2004
    5
    you dont happen to have any links or pics do you
    or know any other machines that have simalar systems
    Jun 2003
    195
    I'll look through my "show info" and see what I can find
    -Tei
    Apr 2004
    5
    thank you very much
    Nov 2003
    181
    if you get onto ESAB's website they should have some picks of their system. We've got one at the college that I go to. It uses a rack and pinion setup and actually it's fairly accurate if it is set up right. I mean give or take a thou or two with a new cutting tip thats nothing that a grinder can't clean up. There is also a 4' by 4' system on ebay that uses a rack and pinion set up. That kind of setup will work just fine considering you don't have a lot of the forces associated with a router.
    Carl
    Apr 2004
    5
    thank you for your help Carl i will take alook at thoes suggestions
  1. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
  2. Fanuc 15MA Time
    By utengineer04 in forum Fanuc
    Last Post: 06-09-2005, 08:14 PM
  3. Time to make it work
    By DESERT RAT in forum DIY CNC Router Table Machines
    Last Post: 02-22-2005, 02:30 PM
  4. Time to wade in ready or not.
    By fair451 in forum CNC Wood Router Project Log
    Last Post: 12-17-2004, 05:14 PM
