587,465 active members*
3,023 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > First time servo user - need some help with G320x
    Dec 2006
    532
    Got keling package few months ago for my mill with NEMA34 servos, g320x and AMT102 encoders.
    Been trying to read up on how to do things right and coming up short, first I installed encoders, pretty sure I did it right? What I don't get about "aligning", do you somehow reference to shaft position? I found nifty animation on how to install them at digikey website, but again, it didn't make sense.
    I plugged power supply in and encoders and I'm getting power light and fault light(power supply supplying 75V), tried wiring in BOB and motor, went thru wires and thought I had encoder wiring screwed up(A=White, B=Brown, 5V=Red, GND=Black) Right? On encoder there are 6 labels for wires but only 5 wires coming out?!?
    Any help with getting started would be great!
    Thanks,
    Russ
    Dec 2006
    532
    Anyone got any suggestions at all?
    Dec 2006
    532
    Everything seems to be well now after talking to Mr. Mariss himself, jumper between pin 5 & 7 wasn't installed properly and didn't reset the fault signal.
    After setting resolution on encoder and plugging servo in it seems to work great, haven't hooked it up to computer yet, but will in few minutes.
    Now just need to tune it and its good to go!
    Thank You Mariss!
  1. First time BobCad user
    By CarltonCNC in forum BobCad-Cam
    Last Post: 11-14-2011, 07:58 PM
  2. Servo Encoder to G320x Signal Problem
    By pupfield in forum Servo Motors / Drives
    Last Post: 03-09-2010, 02:49 PM
  3. First time user with ???
    By londing in forum Community Club House
    Last Post: 06-17-2009, 10:50 PM
  4. 1st Time CNC user...Hoping
    By CROSSHATCH in forum Uncategorised CAM Discussion
    Last Post: 11-03-2007, 06:58 AM
