587,129 active members*
3,187 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > USA Club House > first time using a compression bit on wood, looking for advice
    Feb 2018
    30
    so i was finally able to convince my boss to buy a compression bit, its a whiteside solid carbide compression bit, 1/4 cut 1/4 shank, can compression bits be plunged into the cut like the other bits, i have seen other posts about ramping into the cut and im wondering if that is something i have to worry about with a compression bit, i would like to avoid any potential failures if possible as this is my first time using a compression bit, im running a kongsberg xn and have always plunged into my cuts without any problem
    im using the compression bit to cut 4" coasters out of 6mm plywood and the current settings i have for this are
    rpm - 15,000
    ipm - 125
    Mar 2003
    35538
    Re: first time using a compression bit on wood, looking for advice
    I think I told you before, always ramp if possibly.
    I think 15,000rpm is on the high side.
    How are you holding your parts down? If you are able to hold them down, then cut in one pass, cutting about .005" into the spoilboard. the bit will last longer if you can go a bit deeper.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2018
    30
    vacuum table
  1. need advice, first time using a compression bit
    By bzen in forum USA Club House
    Last Post: 02-21-2018, 08:25 PM
  2. Help/Advice for Compression Die Design
    By cycleback in forum Diemaking / Diecutting
    Last Post: 12-18-2017, 07:47 PM
  3. Replies: 0
    Last Post: 11-30-2013, 04:04 AM
  4. Need Wood Millwork Done Extremely Time Sensitive
    By such&such in forum Employment Opportunity
    Last Post: 09-13-2010, 05:26 AM
  5. Silicon Rubber compression mould advice ??
    By kevh in forum Moldmaking
    Last Post: 05-29-2009, 05:33 AM
