I'm working on milling a shaft using the 4-axis milling machine (A) in SprutCAM Version 8, and I can't figure out how to stop the program from gouging the part in certain areas. I was curious what items of the parameters I need to investigate to figure out this problem. Ive attached the files to access the part and the project. The tools I'm using are a 0.0400 inch and 0.1250 inch end mill. Also, Any recommendations to make the part come out as smooth as possible would be greatly appreciated as well. My tools are limited, but if you feel there would be better tools for me to use for this project, I can order them. Thanks!
