Hi Everyone!
Well after going through the proper channels to aqquire this and save it from the skip (!) and asking a few favours from friends to help move the thing I finally have it and havent paid a penny.
My aim is to turn it into a CNC Mill (I might even be able to add a lathe part to one half).
It uses Linear Motors (thrust tubes) in X Y and Z and Dual THK rails on each axis (with 4 roller guides per axis) except Z (although I will be modifiying Z to be able to take more strain). It also weighs a tonn!
I have all the motor drivers, powersupplys, power distribution panel and baldor din rail IO and multiaxis controllers ..... EXCEPT the dam PCI card. Still shouldnt be too hard to source one.
Current plans differ it being able to do detailed work such as pcb and engraving all the way to cutting aluminiun.
It really is the perfect start.
Im a little worried about the encoder strips being in a garage (would have put it in the house but theres no chance of it fitting through the door).
Anyway Im very busy with work and being that this is a rented property and I wownt have my own until 2007 this is going to be a long term project!
So any advice or ideas? I see alot of people using router's as they are easy to integrate - I have two intial questions:
1). Whats the torque like at low RPM's?
2). Nromally on a mill you have collet (spelling?) to secure the tool, are there any problems using mill cutting tools with routers (reading that it sounds like a stupid question but ill ask it anyway...)
Oh BTW I work in robotics which helps but work with high precision small scale devices nothing this large (before)
Edited to add: it doesnt weigh a tonn, figure of speech
