HI..
I have yet to start building my CNC Table, before I start I was wondering if there is any benfit in a fixed granite?
I thinking of set it half way down the moving table.
Auzze :cheers:
HI..
Auzze :cheers:
You can build a more massive gantry, without having to worry about the extra power or stronger linear bearings to move it. Also, you should be able to get away with a smaller shaft to move the table.
The drawbacks are that the router will only have around half the cutting length for a given footprint, but the bearing shafts will need to be double the length of the table.
