603,864 active members*
5,458 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Apr 2008
    196
    Question Fixed Gantry Design Question
    I have not seen a fixed gantry with the Y axis in the center of the work space. My thinking is this would increase the usable work area & also possibly make for an even more ridgid machine. Thoughts?
    Apr 2007
    8082
    It looks like a good concept to me, but the router and cutter needs to be centered, not the gantry. I like the diagonal structure that makes the gantry more rigid.
    That way the frame and table can be configured so the table can be moved forward and backward from the rear edge to the front edge of the table.
    Likewise, the frame and gantry needs to be wide enough that the cutter can reach each of the side edges of the table.
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2008
    196
    you are correct. The spindle would need to be centered, not the gantry.
    Aug 2008
    409
    I really like the long axis to be the bridge on a fixed gantry machine, it helps reduce the foot print of the machine and maintain many of the benefits of both moving gantry and fixed bridge gantry.
    Ive seen several CR Onsrud machine with this configuration
    CNC Routers, CNC Mills, Inverted Routers, and Tooling by C.R. Onsrud Inc.
    Im doing something similar with my machine, but Its going to be a much different design.
    http://www.cnczone.com/forums/diy-cn..._ridgid_z.html
    I like your design, seems like it would be quite sturdy and solid.
    Feb 2012
    That design looks great, I am definitely adding it to my ideas book! Where were you planning to mount the rails on the gantry - on the side or on the top & bottom faces? IMHO, a top & bottom mount would give less deflection and would save horizontal space.
    Something else you could try to reduce cost and improve the frame stiffness is to add a flat MDF base, which makes sure the frame stays square and generally helps dampen vibration. That would optionally allow the table to be widened and supported from the outer X axis extrusions and eliminate the two inner extrusions. Even if the cutter can not reach the edges of the table, its always handy to have extra space for fixturing.
    Nov 2006
    1036
    I think your design is off to a very good start. I recently made a small fixed gantry router where the moving table axis is slightly longer than the fixed gantry axis. If/when I make another router, I'll strongly consider making the fixed gantry axis the longer of the two (maybe by a lot!).
    Apr 2008
    196
    Quote Originally Posted by Mr Overkill View Post
    I have not gotten that far in the design yeat. I will be working on this over the weekend.
    Apr 2008
    196
    My thoughts on my gantry rails are to put 1 set on each the top & bottom & 2 sets on the front ti minimise deflection of the z axis. Also I am thinking of spreading 4 sets of rails across the table. with this setup I think I should be able to machine aluminum accurately, that is if I wanted to.
    Feb 2012
    Its quite unusual to use more than two rails peraxis. There are several reasons: It's much harder to get the rails lined up: the rails need the be perfectly straight and if you are using supported rails, the surface they are mounted on has to be machined flat. Next, the cost is doubled. Lastly, you will probably get more rigidity from 2 thicker rails than 4 thinner ones. I forget the formula, but doubling the rail diameter vastly increases stiffness, while costing less than double (based on a quick look at the McMaster catalog).
    You can further reduce deflection and increase load capacity by using either extra long bearings or 2 bearings per rail. The lower rail that is nearest to the cutter has the most effect on deflection, so I would look at making that rail the stiffest and saving some money on the upper rail.
    Apr 2008
    196
    here is my latest render. Still a work in progress. Thanks for all of the input. This machine will have a cutting area of about 28" square. Should I go with nema 23 or nema 34 motors. I plan on using ball scres on all axii
    Feb 2012
    Your design is looking even better! I see you are using linear carraiges, which are usually more compact and stiffer than round rails - just be careful about keeping dust out of them.
    I'm no expert on motor sizes, however a guy whom i trust has put a good case for using smaller diameter motors if you want faster rapids and don't need huge torque to push larger cutters thru hard material.
    Apr 2008
    196
    Speed is not what I am shooting for. I am looking more for rigidity & accuracy cutting mainly plastics (Delrin, uhmw, nylatron, & hdpe) & hopefully the ability to machine aluminum. Thanks for the comments.
    Dec 2010
    634
    Quote Originally Posted by ynnek View Post
    Yet!
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Apr 2008
    196
    Quote Originally Posted by BanduraMaker View Post
    Yet!
    I will concede that.
    Apr 2008
    196
    Question
    How about a 4 - 8 auto tool changer. Has this been done on a DIY fixed gantry CNC? I am thinking just add a linear stage to one side or the other to mount the tool holders. Thoughts?
    Attached Files Attached Files
    Aug 2008
    409
    Just a note on your latest drawing, you do not want your table rails to be so far apart. you should move them closer together otherwise you could get sagging in the middle of your table due to lack of support. Having your rails on the edges give little support to the center of the table. I would move them in closer together.
  17. #17
    Apr 2008
    196
    Still designing. I shortened the span between the table guide rails. I thought the outer edges of the table might flex a bit, therefore I added two fixed guides with UHMW strips. I am still thinking a possible tool changer. Thoughts on this design revision?
  18. #18
    Dec 2010
    634
    What's the material for the gantry uprights? Looks like there's plenty of strength in the long axis but it could be flimsy in the short direction depending on what it's made of.
    -Andy B.
  19. #19
    Apr 2008
    196
    1 inch aluminum maybe even steel
  20. #20
    Dec 2010
    634
    Yea, that should probably cover it.
    -Andy B.
Page 1 of 2 12
  1. Fixed Gantry - Trying again
    By harryn in forum CNC Wood Router Project Log
    Last Post: 04-08-2013, 02:51 AM
  2. Small Fixed Gantry Design
    By praneetn7 in forum DIY CNC Router Table Machines
    Last Post: 03-26-2012, 05:08 AM
  3. 8020 Fixed Gantry Design
    By jupdyke in forum DIY CNC Router Table Machines
    Last Post: 12-30-2010, 11:48 AM
  4. Newbie question on Gantry design
    By Tartan5 in forum DIY CNC Router Table Machines
    Last Post: 06-29-2010, 09:53 PM
  5. Gantry design question
    By anthony in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2005, 07:39 PM
