I have an 8'x4' CNC router with hiwin linear rails and cncrouterparts.com r&p drives on the X and Y. I'm upgrading to Parker planetary gearboxes and I am considering a fixed pinion setup. Presently the belt drives have a spring tensioner. I see commercial machines with a fixed pinion such as the Biesse Rover J: CNC Router Biesse Rover J
Would hard fixing the gearboxes to the carriages be viable? I see that the rack must be balls-on parallel to the linear rail, which may be harder said than done. Has anyone implemented anything similar?
