I am building a CNC horizontal mortiser to make mortise and tennon joints in wood. Two of the axis are traditional horizontal linear bering arrangement. The third axis moves a horizontal mounted router up and down on linear slides. I have some desire to mount the screw in a fixed fashion to the router carriage base and have the nut turn. For this application, it makes the design a bit more compact and the motion force is being delivered centered on the cutter axis and near the base. I am desiring 6-8" of travel.
Does anyone know a source or design for a zero backlash nut that has the thrust bearings and timing belt shieve all in one assembly? Is this a bad idea?
Also, my Precix CNC router has a brake on the Z axis so that when power is removed, the head doesn't drop. Do many of the shop built machines incorporate some type of brade for this function?
